Activity Forums Adobe Premiere Pro Batch Exporting with In & Out Points
  • Batch Exporting with In & Out Points
    Posted by Paul Factora on October 17, 2016 at 10:50 pm
    It’s gotta be a simple solution but I’m missing it.
    I’m batch exporting a dozen clips with separte in & out points from the same master clip.
    Media Encoder will then export the full clips and not go by the in & out points.
    How do I ensure the export will contain only the part of the clip that I’ve set In & Out points to?
    -p
    Tero Ahlfors replied 9 years, 11 months ago 3 Members · 2 Replies
  • Duke Sweden
    October 18, 2016 at 1:51 am
    Hey Dave, Could you explain what you mean by making separate timelines? I know you don’t mean separate tracks and I know you don’t mean separate sequences. I googled it but there’s nothing on making separate timelines for each part of a longer clip.
  • Tero Ahlfors
    October 18, 2016 at 3:55 am
    [Paul Factora] “How do I ensure the export will contain only the part of the clip that I’ve set In & Out points to?”
    If you’re doing this in the source window you’ll need to make sure you select the in/out range manually. It will default to the whole clip. There’s a drop down menu below the preview screen in the export window.
    Alternatively you could make subclips from the source clip and batch export them.
