Activity Forums Adobe Premiere Pro Batch export of multiple sequences?
  • Batch export of multiple sequences?
    Posted by Steve Brame on November 4, 2008 at 9:40 pm
    I can’t locate a method for encoding a batch of sequences. In fact, if I select multiple sequences in my Project Window, the ‘Export’ menu item goes gray. I see in the new Adobe Media Encoder CS4 there’s an option to drag additional files to the batch list, but this doesn’t work for sequences. So, are we still required to export sequences one at a time?
    Steve Brame
    creative illusions Productions
    Steve Brame replied 17 years, 6 months ago 1 Member · 1 Reply
  • Steve Brame
    November 4, 2008 at 10:02 pm
    Wow!
    After some experimentation I figured it out. You have to do an export separately to each sequence with the Media Encoder active. This will load each sequence into the Encoder. Kinda strange that they didn’t provide the functionality to just select multiple sequences and select Export, but this is STILL much better than CS3.
    Steve Brame
