Activity › Forums › Apple Final Cut Pro Legacy › Batch export issues
  • Batch export issues
    Posted by Andy Gallagher on May 4, 2007 at 10:12 am
    Hi all,
    I’m running FCP 5.1.2 with XSAN 1.3 on OSX 10.4.7.
    I’ve got a collection of nearly 200 very short sequences which we’re going to run through an encoder to FLV for incorporation into game elements. So I’m trying to batch-export them to photo-jpeg MOVs, then pull those through the encoder.
    Odd thing is, FCP worked fine up to the 16th. Then locked up completely. 17, 18 et al. render and playback fine, doesn’t seem to be any issue with the media or anything. I’ve tried our other Macs, tried leaving it to run overnight, no joy. Manual export is not really an option because of the number of them.
    Upgrading isn’t really an option at present, because we’ve got a cluster of G5’s on the XSAN which all need to be compatible with each other. An upgrade of everything is scheduled, but only once the current projects are delivered…
    Any help would be appreciated!
    Andy Gallagher replied 19 years, 5 months ago 4 Members · 5 Replies
  • Stuart Simpson
    May 4, 2007 at 3:25 pm
    Have you tried keeping the exports the same as the sequence settings? Why do you want to convert to photo-jpeg?
    -Simmie
    2 G5 – Kona LH
    3 G4s – Cinewave
    1 xbox360, 1 PSP, 1 PS2 & a Gamecube
    https://www.speak.co.uk
  • Andy Gallagher
    May 4, 2007 at 3:28 pm
    think that that worked before. However, I’m using Photo-jpeg because it actually looks better than the DV that the sequences are.
    The FLV compression we have to use is pretty harsh, and we had the previous lot (exported as DV) effectively sent back.
    I’ve found that exporting as Apple DV tends to increase the black level of the footage, and we also have to manually set the ‘high quality’ flag on the files in QT pro – not much fun for 100+.
    I’ve just about got it going, doing them 7 at a time, which is better than one at a time! Think it just crashed again though >:-[
  • Nick Meyers
    May 5, 2007 at 8:32 am
    “and we also have to manually set the ‘high quality’ flag on the files in QT pro – not much fun for 100+.”
    you probably don’t need this, now, but there is a small app that will batch modify your QT files to high qual.
    it’s name: Hi Qual!
    https://www.synthetic-ap.com/products/hiq/index.html
    nick
  • Bbalser
    May 6, 2007 at 2:07 pm
    I had this problem on the one occation I had to do a ton of clips at once with Batch Export. I just made several batches, with 25 Sequence each, and it worked fine. Instead of one Batch, I made three, and they went with no problems.
    – Apple Certified Trainer
    – Tutorials at http://www.bbalser.com
    – South Louisiana FCP Users Group
    – NOVAC Digital Filmmakers Institute
    – Event DV magazine
  • Andy Gallagher
    May 8, 2007 at 9:44 am
    Now that’s probably the most useful utility apart from a Mac software-based bread slicer, or maybe FCPRescue… 🙂
