Activity › Forums › Adobe Premiere Pro › batch create sequences from a group of folders or text document contents
  • batch create sequences from a group of folders or text document contents
    Posted by Darren Coombes on February 25, 2019 at 8:24 am
    I have 175 clips and each of these clips has to go into it’s own sequence. Therefore creating 175 different sequences.
    My Issue is, each sequence needs to be a specific name, as its an exercise.
    This way, each sequence then will be export as a seperate shot for compositing.
    Is there a way to batch create sequences in premiere?
    I have all the shots exported as folders, with the same names. Could I somehow use the folder names to create sequences? Or perhaps use a text document where each line of text is a sequence name?
    Would save me a lot of time.
    As future jobs could hold up to 500 + sequences.
    Thanks.
    Bouke Vahl replied 7 years, 7 months ago 2 Members · 1 Reply
  • Bouke Vahl
    February 25, 2019 at 3:49 pm
    I have no clue if it’s possible in Premiere, but in Avid it’s not a big deal.
    If that is not an option, I could make you something that does this.
    (Contact me directly if you would like me to make you an offer.)
    Bouke
    http://www.videotoolshed.com
