Activity › Forums › Apple Final Cut Pro Legacy › batch change “in point”
  • batch change “in point”
    Posted by Mike Johnson on June 5, 2008 at 3:06 pm
    Well, the subject pretty much sums up my question. I have several hundred clips, animated photos from AE. In AE, I started and ended the clip one second before the animation actually begins, to give me handles should I want to dissolve. Now, I can easily set the in and out point for 1.00 and -1.00 respectively one clip at a time.
    But is there a way to set the in and out for multiple clips? I would like to think I’m just missing something extremely obvious. All of these clips are going to have the exact same in and out point.
    Any help?
    Arnie Schlissel replied 18 years, 4 months ago 3 Members · 3 Replies
  • Todd Reid
    June 5, 2008 at 3:20 pm
    https://library.creativecow.net/articles/cowdog/automator.php
    never used Automator myself, but here is a link to a tutorial.
    I think it may do what you need.
  • Mike Johnson
    June 5, 2008 at 3:23 pm
    awesome! never even thought to try automator. i’ll take a look. thanks.
    System 1: G5 2Ghz DP, 1.5 GB RAM, OS 10.3, FCP 4.1, QT 6.4, AE 6.0, 2 TB Xserve RAID through a Vixel 335 Fibre switch, DVCAM SDI a/v and BetaSP Component through AJA IO, NTSC monitor through Videotek VTM100 through IO
    Second System: G4 1Ghz DP, 1 GB RA
  • Arnie Schlissel
    June 5, 2008 at 3:58 pm
    The easiest thing would be to export this as a batch list, then make your changes in Excel or a similar spread sheet, save, import the batch list into a new project & reconnect the media.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
