Activity › Forums › Adobe Premiere Pro › Batch Capturing HDV with timecode in Premiere?
  • Batch Capturing HDV with timecode in Premiere?
    Posted by Rick Redondo on March 22, 2008 at 7:24 pm
    Hi, I’m having a rather difficult situation caused by Sony Vegas 6. I took footage shot on an FX1 in HDV, and to save on disk space I batch captured with timecode at DV resolution, figuring I could recapture the finished project at HDV resolution when done. Apparently this is no problem with Premiere Pro from the listings I’ve seen here, but VERY UNFORTUNATELY Vegas 6 won’t do this simple task, and I don’t think Vegas 7 or 8 will either (though I’m not yet 100% sure of that). So at this point I’m pretty messed up.
    Does Premiere Pro CS3 batch capture with timecode HDV footage?
    I do have the timecode info for my source clips, and if I can capture with Premiere these clips in HDV, I can then replace the DV clips with the HDV in Vegas and should be OK (though even that’s a lot of work!). I’m also looking at Cineform Aspect HD, but if Premiere can batch capture HDV then I won’t need it.
    THANK YOU SO MUCH FOR YOUR HELP! Makes me wish I’d edited with Premiere in the first place, then I wouldn’t have ended up in this mess.
    Sincerely,
    Rick
    Jon Barrie replied 18 years, 6 months ago 2 Members · 1 Reply
  • Jon Barrie
    March 24, 2008 at 12:13 am
    Yes. Open a HDV project in PPro. Import the project/AAF/EDL into the HDV project and offline all the clips. Batch capture them with the HDv settings. All will capture no prob’s. I do it all the time. 🙂
    – Jon 🙂
    How many editors does it take to change a light bulb?
