Activity Forums Apple Final Cut Pro Legacy Batch capture won’t stop at out point.
  • Batch capture won’t stop at out point.
    Posted by Craig Moorhead on November 8, 2007 at 11:02 pm
    I’m re-capturing footage from a Panasonic AG-DVC30. I’m using FCP 5.1.4 on a Dual 2GHz G5.
    The problem is that the capture won’t stop at the out point. All the points are there in the browser window, it finds the in point no problem, but no matter what clip I try to capture, it just keeps running until I stop it. I’ve let it run at least 2 minutes past the out point.
    Any ideas as to why this is happening? This is the same set up I had when I captured this stuff the first time.
    Craig Moorhead replied 18 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
