Activity › Forums › Apple Final Cut Pro Legacy › Batch capture of HDV to ProRes
Alfred Guzzetti
June 17, 2009 at 2:11 pm“direct FW HDV->ProRes does indeed capture TC just fine. I’ve used this for quite some time. yes I have recaptured this way…”
I assume you mean that you recaptured using your Panasonic deck and 422 control, not firewire. When I try to recapture a ProRes clip using firewire, I get an error message saying that I need a controllable device. The Log and Capture window won’t appear with the Firewire HDV to ProRes setting.
Alfred Guzzetti
Mac Pro Quad 2.66GHz 4GB RAM
Intensity Pro card
OS 10.4.9
FCP 6.0 -
Mario Bonassin
August 11, 2009 at 7:23 pmIf i have the Kona card and stuff can I do batch/recaptures from tape if I needed to?
or once I’ve captured in prores is that my new master?
Jiri Fiala
March 9, 2010 at 3:17 pmDavid, how do you go about recapturing HDV ProRes via FireWire with help of EDL? How does EDL fit into this process?
(on related note, HDV to ProRes via FireWire DOES capture TC, on our HD110s anyway)
