Activity Forums Adobe Premiere Pro Batch Capture– no inpoint– didn’t capture anything
  • Batch Capture– no inpoint– didn’t capture anything
    Posted by Richard Milner on August 4, 2005 at 4:32 pm
    After reviewing previous posts, there is an issue that I am having with batch capture.
    Scenes have been logged.
    once logged, Go Into batch capture (DV firewire).
    1st pass– some scenes are captured— others are not.
    Scenes that are not, we try doing another batch capture, it rolls back and goes through the entire clip- or stops right away- in either case a message like “No inpoint” or “nothing captured” is in the batch capture data log.
    any suggestions?
    George Socka replied 21 years, 1 month ago 2 Members · 2 Replies
  • Richard Milner
    August 4, 2005 at 5:59 pm
    We found that it was a sony dvcam deck issue. I don’t know if it’s a settings thing or a equipment failure.
  • George Socka
    August 4, 2005 at 7:48 pm
    Does the first clip start at 0;0;0 – then there is no time code for preroll. I always skip the first few seconds or so to avoid this. If there is really good stuff in the first second, the only way to get it is to capture “manually” problem.
