Activity Forums Apple Final Cut Pro Legacy Batch Capture Blues in FCP6 – or is it my camera?
  • Batch Capture Blues in FCP6 – or is it my camera?
    Posted by Mp Nunan on September 20, 2010 at 3:41 pm
    Hello All –
    This might perhaps be an issue with my camera, but I’m posting my question here anyway:
    It appears that my Sony HD Z1 makes a timecode break every time I button off. (Not power-off, but merely button off between shots.) Therefore, when I try to batch capture, it gets screwed up on the pre-roll, because the time-code is bad.
    So I have to “capture all” – which is time-consuming, and uses a lot of hard drive space.
    This problem does not happen when I shoot in standard definition in NTSC or Pal.
    Is it possible that I’ve got a setting in my FCP6 wrong somewhere? Or is it my camera?
    Many thanks in advance for any advice.
    Mp Nunan replied 15 years, 11 months ago 1 Member · 1 Reply
  • Mp Nunan
    September 24, 2010 at 8:56 pm
    Hi – thanks for the answer.
    Turns out I was able to play with the capture settings in FCP – and it’s not batch capturing.
