Activity Forums Adobe After Effects Batch AVI Audio Normalization?
  • Batch AVI Audio Normalization?
    Posted by Mike Wheeler on October 12, 2006 at 4:59 pm
    Hey..
    I am trying to find a way to normalize audio from over 800 avi files I have, I need to play them in order, but as of now the audio levels on each file is so different it is useless to play them…. is there any way I can take the entire library and even out the audio on each with some sort of batch conversion?
    Thanks, I’m really in a bind here!
    Stefan Tapper replied 19 years, 11 months ago 2 Members · 1 Reply
  • Stefan Tapper
    October 12, 2006 at 5:36 pm
    Adobe Audition can import AVI files. Batch processing with normalisation is no problem(look at the Audition help) and then write them out as avi or wav files.
    Another easy way would be: import everything into AE. Drop the files into the render list and select wav as export. Now you can batch process the wav files with almost any audio application.
    Or throw them all into one comp, create one big wav file and normilize that.
    There are a lot of ways to accomplish it pretty simple.
