Activity › Forums › Adobe Photoshop › Batch action into HDRI Merge
  • Batch action into HDRI Merge
    Posted by Tylor Larson on August 12, 2016 at 7:44 pm
    I need to make a droplet that applies an action to a folder of images, Once that batch action is complete I need to run “Merge to HDR Pro” script. These three images come from a Ricoh Theta camera. They are bracketed images, used to create HDRI panoramas for a reflection map.
    So Currently I’m running a batch action on a folder to content aware fill the bottom 80 pixels to remove the tripod from the three images. Once those images saved, I then have to run “Merge to HDR Pro”. I just want to combine these two steps and only stop once it reaches the HDR Pro script so I can make any fine tune adjustments.
    Tylor Larson replied 10 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
