Activity › Forums › Adobe After Effects › Bass shake?
Bass shake?
Posted by Hannes Skoog on February 26, 2016 at 10:47 amI’m wondering how to do bass shakes like the ones in this Vine: https://vine.co/v/ir5zpVlDvZv
Looks too good to be twitch, he must’ve done it it another way.
Answers are greatly appreciated!
Daniel Waldron replied 10 years, 7 months ago 4 Members · 9 Replies -
Tudor “ted” jelescu
February 26, 2016 at 11:20 amI do not see anything out of the ordinary here- simple Levels, Position and Rotation animation (may be a bit Scale as well), with a Motion Tile applied to make sure the edges do not show up (mirrored) and Motion Blur enabled. The rest is timing. The sprocket holes can be created in AI and then animated on top.
Tudor “Ted” Jelescu
Senior VFX Artist -
Hannes Skoog
February 26, 2016 at 12:53 pmI know all of those effects but I don’t know how to combine them in such a good way, I’m not that experienced in After Effects after all. Do you know if there is any video that explains how to do it?
Tudor “ted” jelescu
February 26, 2016 at 1:27 pmOld friend Google came up with this (a bit more complex than my suggestion but this gives you the option to sync to bass):
https://www.youtube.com/watch?v=5DOCwc62w_0Tudor “Ted” Jelescu
Senior VFX ArtistSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Hannes Skoog
February 26, 2016 at 1:30 pmI’ve seen that video but that gives it more of a pump than a shake, not quite what I’m after.
Chris Evans
February 26, 2016 at 3:06 pmMy advice: Just keep trying stuff till you get something you like. Animate position and rotation the same way as in that tutorial.
You could also use the wiggle expression (just google it if you don’t know), but sometimes that gives weird looking shakes.
Hannes Skoog
February 26, 2016 at 3:30 pmThanks for the advice, though when attempting to do this with Twitch I just discovered that when I apply Twitch on whatever layer the whole program doesn’t respond for a while. After a while it responds but if you do any change in the program it all repeats, AE stops responding for a while.
Is this a known problem? I’m using AE 13.2 here.
Hannes Skoog
February 26, 2016 at 3:44 pmSorry, I ment AE CC 2014.2. The weird thing is, it worked just a few days ago…
Hannes Skoog
February 26, 2016 at 6:01 pmI just found out how to make a nice bass shake, now I need help with After Effects not responding when using Twitch.
Daniel Waldron
February 26, 2016 at 8:48 pmDo you have the latest version of Twitch? I believe it was updated after the original CC was released a few years ago.
