Activity › Forums › Adobe After Effects › Basically Gradient along stroke
  • Basically Gradient along stroke
    Posted by Ted Low on January 11, 2018 at 4:21 pm
    Hi All,
    I know this is not possible in the strictess sense of the title but I’m trying to achieve something similar to the image. I want to be able to change the length of opacity gradient the ring to be smaller and larger through time.
    I’ve used a generate stroke as an alpha while it does work it doesn’t allow me to alter the length of the gradient opacity.
    Thanks for your help guys!
    Ted
    Kevin Camp replied 8 years, 8 months ago 3 Members · 2 Replies
  • Joseph W. bourke
    January 11, 2018 at 5:13 pm
    See if any of this information helps:
    https://forums.creativecow.net/thread/2/1022437
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Kevin Camp
    January 12, 2018 at 12:59 am
    try the circle effect and set the edge property to ‘thickness’ to make a ring. then add the radial wipe effect.
    make sure the both effects have the same center position value, and then scrub the radial wipe completion property a bit and increase the feather property so see if that can do what you need.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
