Activity Forums Apple Final Cut Pro Legacy Basic settings needed. PLEASE
  • Basic settings needed. PLEASE
    Posted by Photoguy on November 7, 2007 at 3:46 pm
    My project is to produce an educational CD or DVD. I want to do a Snapz screen movie of my narrated Keynote presentation to create a QuickTime Movie. I then want to take several of these segments into Final Cut Pro to edit them. I’ve tried dubbing the Snapz movie in Animation, and H.264. Neither of these will import.
    Can someone please get me started on the right foot? What settings should I use for video and audio? What else do I need to know to more forward with this project? Thanks to all in advance.
    Jack Polcain replied 17 years, 8 months ago 7 Members · 24 Replies
  • 24 Replies
  • Tom Wolsky
    November 7, 2007 at 5:04 pm
    Animation should import. What exactly happens when you try to do this?
    I like using Photo-JPEG rather than those as it’s an I-frame compression format rather than intraframe compression. You can get smearing on motion with Animation.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Photoguy
    November 7, 2007 at 5:29 pm
    Thanks Tom,
    It doesn’t play in the viewer. If I render it, it will play in the canvas, but the swoosh build in Keynote overlaps and gets stuck.
    Now, for some reason, my canvas and timeline won’t appear. I’ve hit command 2 and command 3 and nothing. They are both grayed out in the menu.
    I was hoping I could use H.264 as my dubbing compression before importing because it greatly reduced the file sizes and processing times. I don’t know what type of codecs can be used when combining Keynote, Snapz Pro X and FCP.
    I’m very new to this and need your guidance. Thank you. Jon
  • Tom Wolsky
    November 7, 2007 at 6:54 pm
    Open the sequence from the browser. No open sequence no timeline, no canvas.
    All the best,
    Tom
  • Photoguy
    November 7, 2007 at 7:20 pm
    Thanks. I have all the panes now.
    I took a screen shot of the animation problem. How can I send it to you?
  • Tom Wolsky
    November 7, 2007 at 7:41 pm
    You could post it on the web somewhere and send a URL.
    All the best,
    Tom
  • Photoguy
    November 7, 2007 at 7:48 pm
    I have no idea how to do that. I don’t have a website.
    Can I capture in Snapz with H.264 and import into FC for editing? When I try it, it won’t play. But then again neither will Animation.
    Are there initial settings or a set up that I should do?
  • Todd Gillespie
    November 7, 2007 at 7:59 pm
    Unfortunately, Snapz isn’t that good. I switched over to iShowU, which works MUCH better and faster. You do need to make sure that you are using a codec that FCP can edit. NOT H.264
    Start off with some small tests, i would try DV size and codec first. Then work your way to which ever size and codec you prefer.
    Good Luck,
    Todd at UCSB
    Television Production
  • Photoguy
    November 7, 2007 at 8:08 pm
    Thanks Todd.
    I tried iShowU.com to find the software but didn’t see anything. Can you recommend a codec that FC can work with that will keep the file size small and quality high. I know that’s asking a lot. The presentation I’m recording is 1024×768.
    Is there a different program that I can edit a H.264 Snapz show? The QuickTime from it is beautiful and small.
  • Tom Wolsky
    November 7, 2007 at 8:20 pm
    I already recommended codec. Photo-JPEG. Do not try to compress the video before you work with it. That will just degrade it. Make it the best quality you can.
    All the best,
    Tom
  • Photoguy
    November 7, 2007 at 8:49 pm
    Tom,
    I tried PHOTO – jpeg. It wouldn’t play either. Is there someplace to find a step-by-step, on this?
Page 1 of 3
