Activity Forums Avid Media Composer Basic question: How do I import and re-link an aaf?
  • Basic question: How do I import and re-link an aaf?
    Posted by Aaron Neitz on March 31, 2014 at 9:31 pm
    I’m a flame artist struggling with an aaf that won’t import into Flame.
    I’m first trying to see the edit in MC7 on Mac. I have a USB drive from the editorial with a master folder of the project, within are an aaf file and a “Avid Media Files” folder with all the mxf media. I can import the aaf and get a bin with all the clips “offline” but how do I get Avid to connect the edit to the mxf files?
    We’ve had problems with aaf before. What I’ve done in the past is import the aaf into MC7, find a delete the ramped timewarps, then rexport. Flame has no problem reading and reconnecting to the mxf. This time something else is wrong. BTW I’ve been googling for 4 hours and an still stymied on this reconnecting mxf issue.
    Michael Phillips replied 6 years, 11 months ago 5 Members · 5 Replies
  • Shane Ross
    March 31, 2014 at 9:48 pm
    For Avid to see the media, they need to be located on a root level of a drive, in a folder called “Avid MediaFiles” (exact name and caps needed), and then in that, an “MXF” folder, and then in that, numbered folders containing the MXF files.
    Shane
    Little Frog Post
  • Aaron Neitz
    March 31, 2014 at 10:18 pm
    Thanks Shane. I moved the files on the drive to reflect that structure and it worked.
    Now to figure out where the pesky bug is.
  • John Pale
    April 1, 2014 at 3:03 am
    Try re-exporting the AAF from Avid, but this time check “Use AAF edit protocol”
  • Jayasri (joyce) hart
    October 10, 2019 at 2:45 am
    Hi Shane!
    You always have the answer. Thanks. Do you know if any of the Media Composer 2018 User Guides has this information. And if so, in which chapter?
    Best,
    Joyce
    Jayasri (Joyce) Hart
    Los Angeles, USA
    http://www.linkedin.com/in/hartfilms/
  • Michael Phillips
    October 10, 2019 at 2:49 pm
    I’ve never been able to get a clear response from Avid as to what differences to expect between Edit Protocol being checked or not. I did find through some trial and error that custom column metadata on source clips was not exported when Edit Protocol was checked.
    Michael
