Activity Forums Adobe After Effects basic question about masking
  • basic question about masking
    Posted by Randy Hunter on October 23, 2009 at 3:45 pm
    i need create a mask to isolate a moving figure out of the background and i need the mask to move to match the movement of the figure.
    example: isolate an image of hand opening and closing and set against a black background.
    there’s a lot of movement within the frame and of the frame itself so i haven’t had much luck using the motion tracker. i’ve also tried to go through and use the pen tool to mask out the image but i haven’t been able to figure out how to lock in the adjustments to each frame while altering the mask on the next frame
    i’m sure this is a easy fix for somebody a little more savvy than myself, but any help would be appreciated
    Todd Kopriva replied 16 years, 11 months ago 2 Members · 1 Reply
  • Todd Kopriva
    October 24, 2009 at 4:14 pm
    Here’s a good place to start: “Rotoscoping introduction and resources”.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
