Activity Forums Adobe Premiere Pro basic premiere to bluray render settings
  • basic premiere to bluray render settings
    Posted by Glenn Angel on May 2, 2011 at 8:57 am
    Hey pplz,
    Im finishing my first ever project on premiere after working for years on vegas!
    My footage ranges (sadly) from 1440×1080 mts files, 1280×720 MOV files and a few SD JVC Mod files (changes to .mpg) all in 25 fps.
    I have chosen mpg2 blu-ray as the format, (1440×1080) but i have seen some pplz change from VBR 1pass to 2pass… and also play around with the rates.
    Also, shoul di turn frame blending on/off?
    And finally should audio by PCM or dolby digital, i usually use dolby codecs for DVD audio on vegas, but im just learning premiere..
    Any help woul dbe great.
    Currently it says a 17min video is set at about 3GB. I would have expected larger but thats fine!
    Edit:
    I just checked and somone suggest use H.264 so iill use that not mpg 2, but the above questions still apply 🙂
    edit 2:
    I will be using Encore to author
    Glenn Angel replied 15 years, 4 months ago 2 Members · 2 Replies
  • Ann Bens
    May 2, 2011 at 9:05 pm
    Its better to downscale than to upscale.
    I would stick to dvd. BD will never look good with the SD footage.
    You could try this but its only for AE.
    https://www.redgiantsoftware.com/products/all/magic-bullet-instant-hd/
  • Glenn Angel
    May 3, 2011 at 3:00 am
    Thanks Ann,
    I didnt mention it in this clip but 90% of the footage is the 1080i footage with only about 25 seconds of a 19 minute video being the SD footage. I know its going to look rubbish, but in the end i though to go with the most used. Its for an amateur wedding video however ive learnt my leson and next time ill be using a canon to shoot in 1280×720 as well as the Sony (1080i) and a Canon 5D for the Full HD shots!!! (Stupid jvc)
    Ill ahve a look at link, cheers
