Activity › Forums › Apple OS X › basic Mountn Lion Install Q – do I have to REinstall FCP, etc onto same drive after?
  • basic Mountn Lion Install Q – do I have to REinstall FCP, etc onto same drive after?
    Posted by Stu Aull on September 19, 2013 at 9:40 am
    Hi Folks –
    OSX 10.6.8
    Mac Pro 2011 12 core/14GB
    FCP 7.0.3
    have all the above on 2 internal drives (so, a safety boot drive of same)
    LIke to update primary HD with Mtn Lion. (and later the 2nd drive once I know its all good)
    The Q-
    will the current software/apps on the main drive remain intact? ie just the OS software is replaced… or do I then have to manually reload every app (FCP, photoshop, etc, etc) back into this drive?? gads….
    thanks
    Stu Aull
    Alaska
    John Fishback replied 13 years ago 2 Members · 1 Reply
  • John Fishback
    September 21, 2013 at 1:26 pm
    The best practice is to do a clean install then reinstall your apps. You already have a bootable backup of your current config which is good. For more protection you might want to remove one of the 2 drives with 10.6 and install 10.8 onto a new drive. Later, after you backup 10.8 to your second drive, you still have the 10.6 drive in case you need to go back to that.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
