Activity Forums Creative Community Conversations Basic motion attributes change when rendered
  • Basic motion attributes change when rendered
    Posted by Marcel Kunzler on June 20, 2011 at 2:14 pm
    Hello.
    I’m editing a multi screen film and using a bunch of basic motion attributes. I set them and watch them correctly in preview mode, but whenever I render them, those attributes I’ve set look different.
    The numbers and percentages I’ve set don’t actually change, but they look visually different from what I’ve done previously.
    I tried exporting to see if the problem continues, and it does.
    I’m using a timeline with ProRes codec and my media is a mix of ProRes and DV. Might that be the problem?
    Using FCP 7.0.2
    Thanks for your help!
    Marcel Kunzler replied 15 years, 2 months ago 2 Members · 2 Replies
  • Hector Berrebi
    June 20, 2011 at 3:17 pm
    Though this is the FCPX forum, where we never have these kind of problems… I’ll try and help you just this once
    When you made the changes
    Were you monitoring properly?
    And, was your canvas set to 100%?
    If you looked at a resized canvas and don’t use a monitor, some motion attributes might look distorted.
    Hector Berrebi
    prePost Consulting
  • Marcel Kunzler
    June 20, 2011 at 5:32 pm
    Sorry I posted on the wrong place. Was on a hurry.
    I was on a MacBook on the fly, so I didn’t have any external monitoring. The canvas was set to fit window, which was at about 40% of the actual frame size.
    Let me give you a more specific example of the problem.
    I got an image, scaled it to 50% of its size and placed it on the top left corner of the frame. Got another one, did the same and placed it on the bottom right corner. Played it in preview, everything was fine. Rendered, and both images weren’t at the far left and far right corners, they where near the action safe guides. Then I threw away the renders and when they go back do preview, they’re on the far corners again.
