Activity Forums Avid Media Composer Basic Keyboard shortcut
  • Basic Keyboard shortcut
    Posted by Jahil Maplestone on October 18, 2007 at 1:25 pm
    I know this is simple but is there a keyboard shortcut to switch between segment mode and the position indicator or do i have to make my own. I prefer shortcuts for almost everything and can’t seem to find it in the help.
    Jon Zanone replied 18 years, 11 months ago 2 Members · 1 Reply
  • Jon Zanone
    October 19, 2007 at 10:20 am
    [Jaggers] “the position indicator”
    Do you mean the edit mode?
    If you go to your settings mode, and click on ‘keyboard’, you’ll get a graphic representation of your keyboard. Open the command pallette, and you’ll see all the mappable shortcuts. Make sure the ‘button to button’ button is activated at the bottom of the pallette. Click and drag from the command pallette to the keyboard. If you’d like menu items on the keyboard (new title, for example), click the ‘menu to button’ button is activated. Click on the key you would like to change, and move your mouse to the appropriate menu and click to select.
    Is this what you mean?
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
