Activity Forums Apple Final Cut Pro Basic Cross Dissolve question
  • Basic Cross Dissolve question
    Posted by Jordan Mena on February 27, 2013 at 8:58 pm
    IF I just want to add a cross dissolve to a basic clip why does it had the dissolve to both sides of the clip. I just want to add it to the end.
    What am I missing?
    Thanks, J
    Jordan Mena replied 13 years, 6 months ago 4 Members · 4 Replies
  • Loren Risker
    February 27, 2013 at 9:21 pm
    This can be frustrating. There are a few ways to do this.
    Change the opacity of the clip to do your fade instead of a cross dissolve.
    Use a gap clip that’s just the right length.
    Connect your second clip to the storyline as opposed to editing it right next to the dissolve.
    Anyone have a better solution? I usually just use the opacity option.
    OutOfFocus.TV – Original series, music videos, and entertainment for your couch.
  • Mike Drew
    February 27, 2013 at 9:40 pm
    Do you mean the end of the edited piece as in fade out or do you mean dip to black between clips. If it’s fade out then just click the end of the clip and hit command-t. If it’s fade to black between clips, use Fade To Color. Or do it manually as was suggested. But maybe I’m misunderstanding what you’re trying to do.
  • Fabrizio D’agnano
    February 27, 2013 at 11:20 pm
    If you select the whole clip the cross dissolve applies to both ends. If you click on the cut and press command-t the cross dissolve applies to the cut only.
    Regards
    Fabrizio D’Agnano
    Rome, Italy
  • Jordan Mena
    February 28, 2013 at 8:26 am
    Thanks. command T did the trick.
    Tchao~
