Activity › Forums › VEGAS Pro › Basic Batch Audio Rendering Question
  • Basic Batch Audio Rendering Question
    Posted by Linda O’connell on November 11, 2015 at 11:54 am
    I have seen a lot of detailed information on batch rendering here..but nothing about the basic way of doing it.
    I have an audio track that I want separated into different files. I have marked them but every time I chose the option it just renders as one complete file.
    My questions are:
    Do I mark the selections with a “M” or “N”?
    Do I highlight the entire selection?
    I am going to Tools, Scripting, Batch Rendering, MP3 128Kbps…do I chose Render project or render selection? It does not give me an option for render regions
    Or am I totally off and should be doing this a different way?
    I do not care about the names of the files.
    I know I am missing something simple here..but have tried everything 5 different ways! Thanks in advance.
    Mike Kujbida replied 10 years, 10 months ago 2 Members · 9 Replies
  • 9 Replies
  • Mike Kujbida
    November 11, 2015 at 12:03 pm
    Mark your selections with an “r” (region) and try it again.
  • Linda O’connell
    November 11, 2015 at 12:18 pm
    It allows me to mark one region with an “R” but then the option doesn’t work..it’s grayed out.
    I should be marking each audio song, correct?
    Not the entire track? Otherwise how will it know where to divide?
  • Mike Kujbida
    November 11, 2015 at 12:23 pm
    Mark each and every separate section with an “r” and you should be good to batch render.
  • Linda O’connell
    November 11, 2015 at 12:27 pm
    Not to be annoying…but why is the “R” grayed out? It doesn’t allow me to anymore than 1.
    Update: figured it out…I had the track highlighted that’s why it wouldn’t work.
    Thanks for your help!
  • Mike Kujbida
    November 11, 2015 at 12:41 pm
    You need to double click each selection to highlight it and then press “r”. You should be able to do this as many times as needed.
  • Linda O’connell
    November 11, 2015 at 1:09 pm
    I think I got up too early…
    Got the R’s figured out…each song is separated by an R
    But still rendering as one track.
    I am choosing: Batch Render
    MP3 128 kbps
    Do you highlight? Do I chose Render project/regions etc?
    I figured it would be render regions but it’s still giving me one track.
    I don’t mean to be annoying but been working on this for an hour and can’t figure it out.
  • Mike Kujbida
    November 11, 2015 at 1:28 pm
    You didn’t get up too early. I just tried it using the suggestions I’ve made and your template and I only get one file as well. This in spite of the fact that I can see it rendering each separate region 🙁
    Got it!! You have to name each region first. Then do your batch render and then it works 🙂
  • Linda O’connell
    November 11, 2015 at 1:32 pm
    Ok..update again. I figured it out!
    It is very important to double click (like you had said) to select the region. When you do, each region will say 1/2 then 2/3 etc.
    I was just hitting the “R” button so it just came up with 1/1 2/2 and that doesn’t work.
    Just posting this so someone else may not have to struggle like I did.
    Thanks for your help John!
  • Mike Kujbida
    November 11, 2015 at 1:44 pm
    Glad you got it figured out. Happy rendering 🙂
