Activity Forums Maxon Cinema 4D Basic Animation Question
  • Basic Animation Question
    Posted by Dave Montague on October 19, 2016 at 7:34 pm
    I have the new r18 and it seems that when I used to place a primitive, like a cube, on the stage I could keyframe it, then move it, and keyframe it again, and then move it one more time and keyframe it. It would create three points on the animation path. I could easily use the bezier selection to create a nice curve between point a and c. Right now it appears to be adding a point with every frame. Am I up in the night or is there a way to set it C4D to only add a point where I keyframe with no in between frames being key framed?
    Make sense?
    Tks,
    Dave
    Adam Trachtenberg replied 9 years, 10 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    October 19, 2016 at 11:03 pm
    There shouldn’t be extra keys created. On the animation path you should see big dots for the keyframes and small dots for the interpolated keys. You can only manipulate the actual keys.
