Activity Forums Apple Final Cut Pro Legacy Baseline settings to cut in PAL standard def & convert to NTSC
  • Baseline settings to cut in PAL standard def & convert to NTSC
    Posted by Brian Waz on July 27, 2009 at 8:12 pm
    Can someone give advice on what settings to use while cutting a show in standard def PAL, and creating an NTSC output? The material used has all been shot in PAL (and archive footage) and needs to end up in NTSC. I’ve tried some tests, but get “Shift field” errors and think it’s a combination of the PAL timeline and the NTSC conversion. (I’ll be using Automatic Duck to bring it to Avid for output)
    thanks in advance
    Brian
    Brian Waz replied 17 years, 1 month ago 1 Member · 1 Reply
  • Brian Waz
    July 28, 2009 at 4:00 pm
    Can anyone offer a suggestion to a newbie on FCP?
