Activity Forums Adobe Photoshop banding on gradients
  • banding on gradients
    Posted by Iannorthrop on June 28, 2007 at 7:03 pm
    Hello,
    Can anyone explain to me why banding occurs in gradients?
    I’ve been told it has something to do with 8bit per channel color and it’s limited colorspace but how do I get around this? Is there a workaround to smooth out my grads?
    ian
    Iannorthrop replied 19 years, 2 months ago 2 Members · 4 Replies
  • Darby Edelen
    June 28, 2007 at 10:31 pm
    You can work in 16bpc to smooth the gradient further, or add noise/dithering to the gradient to make it appear smoother.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Iannorthrop
    June 29, 2007 at 4:10 pm
    Thank you very much. Working in 16bpc certainly helped. I’m afraid I don’t quite get the add dithering recommendation though. Could you explain further?
    ian
  • Darby Edelen
    June 29, 2007 at 7:25 pm
    Adding noise to a gradient, or dithering the gradient (which essentially adds noise but in a more intelligent manner), will cause the straight lines you see to have more of a diffuse characteristic. So instead of seeing bands of quantization in your colors, the colors become more integrated as the pixels of each color move across the line and form a diffuse edge rather than a straight edge (there is still the same number of colors/the same quantization, it only appears less banded).
    Changing to 16bpc should actually increase the number of colors that can be represented from 16,777,216 to 281,474,976,710,656 =)
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Iannorthrop
    June 29, 2007 at 7:38 pm
    great. feel like I’ve learned alot. thank you.
    I’m not finding the dither checkbox on the “layer styles” gradient overlay. I do see it when using the tool manually. so that solves that.. I’ll only use the gradient tool from the tools window to take advantage of the dithering/diffuse qualities. thanks again.
    ian
