Activity Forums Adobe Premiere Pro Banding issues 10 bit monitoring in Premiere CS6
  • Banding issues 10 bit monitoring in Premiere CS6
    Posted by Paul Jay on August 9, 2012 at 1:21 pm
    I’m having problems getting a proper 10 bit output to my Dreamcolor monitor from Premiere CS6.
    It works perfectly in FCP7 but not in Premiere CS6
    I’m using a Decklink Extreme 3D.
    Because this setups works perfectly in FCP7, i assume this must be Premiere/Decklink related.
    In FCP7 i create a animated gradient in a 10 bit Sequence.
    10 bit Playback settings from the Decklink to a AJA HDP2 through a Dreamcolor.
    Render timeline. Result:
    Perfect Smooth image on the Dreamcolor
    I Do the same in Premiere CS6 with a 10 Bit Sequence, 10 bit playback. Banding all over the place.
    It’s easy to reproduce.
    You can use any 10 bit gradient or blurred circel.
    It’s the same for After Effects.
    Any ideas?
    Jos Wabeke replied 13 years, 10 months ago 3 Members · 5 Replies
  • Walter Biscardi
    August 9, 2012 at 2:09 pm
    In Premiere Pro if you have the Video Previews set to I-Frame MPEG you’ll never get a clean 10bit render because that’s a very lossy compression.
    Switch that to DNxHD or ProRes 10bit and you should get a cleaner render. That’s what we do for all final renders from the Master Timeline.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “This American Land” – our new PBS Series.
    Blog Twitter Facebook
  • Paul Jay
    August 10, 2012 at 10:25 am
    The Video Preview in Sequence settings was set to YUV 10 uncompressed.
    With ProRes 10 bit , it was no difference.
    Real time monitoring is still full of banding.
    My problem isn’t the render. I need a full quality blackmagic 10 bit playback on my Dreamcolor during edit.
    You can easily test this. Create a animated Gradient or a blurred circel in a 10 Bit FCP sequence. Export.
    Import the file in Premiere. And try to get a proper 10 bit image on a 10 Bit Monitor.
    That same quicktime works perfect when importing back in FCP7 and playback Blackmagic 10 bit.
    The gradient is ultra smooth.
    Not in Premiere.
  • Paul Jay
    August 13, 2012 at 1:57 pm
    I challenge anyone to test this. It’s not an isolated issue.
  • Paul Jay
    August 15, 2012 at 8:51 am
    Not in Premiere.
  • Jos Wabeke
    October 26, 2012 at 9:34 am
    Paul,
    I’m having the exact same issues running the same setup as you are: A mac pro running both windows and osx, decklink hd extreme 3d, aja hdp2 and hp dreamcolor monitor. I know it used to work when i just bought the kit. Now when i open up after effects (i’m more of an online guy) set my project to 32 bit, add solid, slap on the gradient and output results in…. BANDING! D&mm!t! Not what i invested in… No 10 bit output on my dreamcolor.
    Also i’ve contacted my hardware supplier who run the same setup, they too had the same result. Again, works fine in fcp7. They were to investigate, have yet to hear from them.
    Also contacted blackmagic, no reply…
    I feel lost here… no-one seems to care 🙁
