Activity Forums Apple Final Cut Pro Legacy Ballooning file sizes
  • Ballooning file sizes
    Posted by Scott Allen on September 8, 2010 at 3:18 pm
    I have a strange problem. At our film archive, we capture standard definition video from a DigiBeta deck to Final Cut 7.0.2, through a Matrox MXO2 box, as “Matrox MXO2 – Uncompressed NTSC 8-bit 48 kHz”.
    Up until the last few months, our resulting file sizes would be roughly 1.33 GB per minute. Now, they’ve suddenly jumped to being 3 – 4 GB per minute. The settings are the same. The software is the same. The hardware is the same. I can’t see any difference, except for the ballooning size of the files. (And no, the video doesn’t look twice as good 8^). We have had ongoing problems with dropped frames and freezing FCP windows, but these pre-date this issue, and they (usually) go away after re-booting/scrapping preferences.
    Any suggestions would be greatly appreciated. Thank you.
    Scott Allen
    2.66 GHz Quad Core Intel Xeon
    8 GB memory
    Shane Ross replied 16 years ago 3 Members · 5 Replies
  • Shane Ross
    September 8, 2010 at 4:41 pm
    Trash FCP preferences. Uninstall and reinstall Matrox drivers…get the latest ones.
    Shane
  • David Roth weiss
    September 8, 2010 at 5:00 pm
    [Scott Allen] “we capture standard definition video from a DigiBeta deck to Final Cut 7.0.2, through a Matrox MXO2 box, as “Matrox MXO2 – Uncompressed NTSC 8-bit 48 kHz”. “
    Time to start using ProRes my friend. 8-bit uncompressed is 20th century technology…
  • Scott Allen
    September 8, 2010 at 8:37 pm
    [David Roth Weiss] “Time to start using ProRes my friend. 8-bit uncompressed is 20th century technology…”
    Well, while I’m all for using this century’s technology (8^), we’re pretty concerned about using either uncompressed, or losslessly compressed codecs. I read conflicting things about ProRes and compression. “Visually lossless” is great for display, distribution, etc, but for archiving, that doesn’t promote total confidence.
    Are any of the high-end ProRes codecs truly lossless? Also, what about either jpeg 2000 or photo-jpeg? My current boss seems pretty high on these, but each seem to have their own issues, either with compression or functionality within Final Cut.
    Scott
  • Scott Allen
    September 8, 2010 at 8:41 pm
    [Shane Ross] “Trash FCP preferences. Uninstall and reinstall Matrox drivers…get the latest ones”
    Thanks. The FCP prefs have been trashed (many times), but we haven’t tried uninstalling/reinstalling the Matrox drivers. We have the latest ones.
    If that doesn’t work, I’m thinking about re-installing Final Cut, or even the Mac OS itself.
    Scott
  • Shane Ross
    September 8, 2010 at 10:20 pm
    ProRes is 10-bit. Uncompressed 8-bit is…well…8-bit. You will have less compression artifacts with ProRes 422 than you will with uncompressed 8-bit. It is a VERY EFFICIENT compressed codec. Like Avid’s DNxHD line. Perfect for ARCHIVING. Since uncompressed is so large. Unless you want to archive and be able to give that to multiple-edit systems. Then Photo JPEG would be the answer, but you can’t capture directly to that format.
    Do this. Capture a clip as 8-bit UC…then the same clip as ProRes 422. Look at the footage, with your eye, on the scopes. Judge for yourself how this codec holds up.
    Shane
