Activity Forums DaVinci Resolve Balancing colour of the trees in different shots :)
  • Balancing colour of the trees in different shots :)
    Posted by Chris Cory on August 3, 2014 at 11:28 am
    Hey
    I have been using resolve for bit and im starting to get my head around it.
    Though does any one have a good suggestions for balancing the colours of the leafs on the trees?
    Here is an example.
    Any advice or tips would be greatly appreciated.
    https://f1.creativecow.net/file/7812/7812_eg.jpg.zip
    Chris
    Chris Cory replied 12 years ago 3 Members · 4 Replies
  • Aurie Anden
    August 12, 2014 at 9:28 am
    I keyed the warm greens and then shifted the hue to match your cooler greens. It was a rather clean key so I think it shouldn’t be too much trouble for you.
    7860_7812egbal1.5.1.jpg.zip
  • Chris Cory
    August 15, 2014 at 5:37 pm
    Hey
    Thanks again for this.
    Can you go into a bit more detail about how you did it, getting the trees the same colour is something I have not been able to do.
    What did you use to shift the hue?
    Thans Chris
  • Aurie Anden
    September 4, 2014 at 10:48 am
    Hi Chris. After getting a clean key of the warrm greens, I just used the “Hue” control to shift the color. That control should be in the color page below the color wheels. It’s right under the “Gain” color wheel. 🙂
    Use that in conjunction with saturation until you get the color you want.
    cheers
  • Chris Cory
    September 4, 2014 at 10:33 pm
    Thankyou!!
