Activity › Forums › Maxon Cinema 4D › Baking Xpresso expression driven mograph animation
  • Baking Xpresso expression driven mograph animation
    Posted by Földváry András István on July 31, 2023 at 4:20 pm
    Hi there!
    My question is whether there’s a practical way to bake a MoGraph animation controlled by an Xpresso expression in Cinema 4D. The Xpresso Expression tag is on separate Null Objects, which affect various splines and cloners. Also there are several Linear Fields that also affect the final animation. I’d like to bake everything together. If I simply choose “Bake As Alembic,” the animation falls apart. What could be the correct approach?
    George Charoupas replied 3 years, 2 months ago 2 Members · 3 Replies
  • George Charoupas
    July 31, 2023 at 9:53 pm
    Hello, I can think of an approach but it is hard to describe in text. Can you share your cinema 4d file?
    I dont think that everything can be baked. There is no option to bake linear fields apart from the cache tag and I am not sure if it can calculate your linear fields correctly. I can try though.
    Thanks.
  • Földváry András István
    August 1, 2023 at 10:13 am
    Can i have your email address?
    And I will send you the link.
    Thank you!
  • George Charoupas
    August 1, 2023 at 10:45 am
    labaxp@gmail.com
    Send it here.
