Activity › Forums › Maxon Cinema 4D › Baking out PolyFX with effectors to bring into Unity
Posted by Eric Youngstrom on April 5, 2016 at 11:18 pmI am trying to bake the random and plain effector and polyfx animations so that I get keyframes for every polygon that the polyfx effects, in order to render out a fbx and bring that fbx into unity.
Can anyone help me out please?
Eric Youngstrom replied 10 years, 5 months ago 2 Members · 6 Replies -
Adam Trachtenberg
April 6, 2016 at 5:33 pmThe donation-ware SteadyBAKE plugin will do it: https://tcastudios.com/?page_id=6
Eric Youngstrom
April 6, 2016 at 9:53 pmMy co worker has tried SteadyBake and I have tried NitroBake. So far both plugins gave keyframes on every frame in the time line for the entire object and not each individual polygon face. He could have done something wrong (he is a maya user) but thus far we still have not found a solution
Eric Youngstrom
Adam Trachtenberg
April 7, 2016 at 2:18 amThe plugins work by recording point-level animation, so you’ll get the same look as if it was individual objects but with a single object.
Eric Youngstrom
April 7, 2016 at 5:06 pmYes, that works for baking the large object as a whole but in this scenario we would need each individual polygon of that larger object to have individual xyz, rotation and scale keyframes. So is there a way to break down that larger object to each individual polygons, but keep the same animation driven from polyfx, and then bake out that animation?
Eric Youngstrom
Adam Trachtenberg
April 7, 2016 at 5:55 pmI don’t think you’ll get the result you want with the PolyFX object, but you should be able to with the Fracture Object.
So, first select all of your objects’ polygons and run the Mesh>Commands>Disconnect function (with “preserve groups” unchecked).
Then place your object in the Fracture Object and set the Fracture’s mode to “explode segments”. Apply the effectors to the Fracture and then use SteadyBAKE or NitroBAKE on the Fracture Object.
That should do the trick.
Eric Youngstrom
April 9, 2016 at 3:39 pmYou sir are a genius, that worked perfectly. Thank you!!!!
Eric Youngstrom
