Activity › Forums › Adobe After Effects › Baking Multilayered effects into individual layers
  • Baking Multilayered effects into individual layers
    Posted by Luke Bicevskis on March 17, 2009 at 1:39 am
    Hi all, got a question.
    Does anyone know of any way to actually bake in a multilayered effect into each of the affected layers.
    My problem is I have a comp using a couple of glow effects to affect different layers to different degrees.
    If you have used glows, you will know that they work best as adjustments using multiple layers to trigger the glow and acting in an additive way, as would occur with real life blooming.
    SO….my problem is this. A client is now asking for sep. layers from the comp to be rendered out for later use, but by rendering the layers sep. I loose a lot of the final glows as the layers are put on solo mode.
    Is there a way to “bake” (or proxy or whatever) the glow into each layer, or somesort of multi-layer render I can do which will give me seperate passes, while retaining the effects of the full comp?
    I hope this makes sense.
    Only Idea i have is doing a PS sequence, which should have the sep. layers, but would be easier if I could do this straight into sep. quicktimes.
    Thanks.
    Chris Wright replied 17 years, 6 months ago 3 Members · 2 Replies
  • Todd Kopriva
    March 17, 2009 at 3:30 am
    Sorry for answering a different question than the one that you asked, but this struck me:
    Why not just work in 32-bpc (HDR) color for “real-life blooming”? If I’m envisioning what you’re doing correctly, then this would allow you to use one instance of the Glow effect to do what you’re currently doing with multiple instances. But maybe I’m misunderstanding.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Chris Wright
    March 17, 2009 at 4:48 am
    For it to work easily, you would have had to setup it up a certain way in the first place so that you could simply take precompose glow #1, precompose glow #2 etc. and set them as adjustment layers with the adjustment layer button turned on – all in a new comp for any new graphics.
