Activity › Forums › Maxon Cinema 4D › Baking Cloth Thickness with animation > FBX/Unity
  • Baking Cloth Thickness with animation > FBX/Unity
    Posted by David Baxter on May 31, 2017 at 10:46 am
    I’m working on a gear VR project in Unity, and have been using an xpresso system to bake mograph animations into FBX files so I can trigger in Unity. It works fine, provided the animations aren’t insanely large.
    For a particular animation I’m trying to solve, I want an icosahedron sphere to procedurally assemble with a random or plain effector, but with thickness, which it seems cloth surface is the best method to create the extrusions.
    Is anyone aware of a way to bake this into an object or objects, and still use effectors to break it apart? Or maybe a better method of adding thickness? I’ve played about with explosion FX without much joy.
    David Baxter replied 9 years, 4 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 31, 2017 at 3:24 pm
    I just tried a basic test with the NitroBake plugin and it seems to work. It gives you separate objects for the original polygons and the cloth extrusion, but the animation holds together.
  • David Baxter
    May 31, 2017 at 3:51 pm
    Aah, I don’t have that plugin but good to know thanks.
    I figured out I could could disconnect/poly to objects, apply cloth then bake and then use fracture/effectors. But by disconnecting the polys to objects first I do get weird extrusions, looks cool when subdivided and useful for this segment, but maybe not good for others.
