Activity Forums Maxon Cinema 4D Bake Spline Mask
  • Bake Spline Mask
    Posted by Chris Thompson on February 19, 2016 at 1:59 am
    Hi all,
    I’m having a bit of a problem as I have a bunch of small animations that need to be exported in FBX format, however many of them have Spline Masks which cannot be exported in this format. So, my question is – is there a way to bake a spline mask? I’ve tried the Nitobake and Steadybake plugins but have not had any luck so far. Could Xpresso be the answer? I’ve tried but failed to create a spline that replicates the Spline Mask inside Xpresso but my knowledge in that area needs some sharpening.
    I’ve included a c4d file that shows an example of the kind that I’d like to export in FBX format.
    https://f1.creativecow.net/9798/bake-spline-mask?uploaded=file
    Any ideas?
    Brian Jones replied 10 years, 6 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    February 19, 2016 at 5:30 pm
    I don’t think it’s possible because the spline masks are essentially generating new geometry every frame. I believe Alembic is the only export format that would work.
  • Chris Thompson
    February 26, 2016 at 9:51 am
    Hey Adam,
    Unfortunately it seems Alembic only exports polygons, and I was working purely in splines. Bit of a bummer. However, I’ve just discovered Bodymovin https://github.com/bodymovin/bodymovin which allows you to export AE shape layers as JSON files which is perfect for my needs as I was porting everything over to MaxMSP.
    Thanks again!
    Chris
    http://www.lumiko.com.au
  • Brian Jones
    February 26, 2016 at 2:54 pm
    Alembic does splines but you have to check them on export and import (called Curves perhaps on import)
