Activity › Forums › Maxon Cinema 4D › Bake Metal in C4D
  • Bake Metal in C4D
    Posted by Zach Schershcsdhbv on December 8, 2015 at 12:36 am
    Help! I have been trying to bake an object with reflections that match my render (blurry metal) with no luck. I am using the bake texture tag and the reflection always comes out clean and doesn’t match my render!
    Any help would be greatly appreciated!
    Brian Jones replied 10 years, 9 months ago 2 Members · 3 Replies
  • Brian Jones
    December 8, 2015 at 3:03 am
    the help for Bake Texture Options/Reflection says “When rendering reflections, one exception applies compared with the other material channels: Here you don’t have to specifically activate Reflectance – reflections will be baked regardless.”. You’d have to ask Support to be sure but I have to guess it means it’s not going to listen to reflectance settings since it doesn’t even need them to function.
  • Zach Schershcsdhbv
    December 8, 2015 at 12:57 pm
    Thanks Brian!
    I have read that too, but it doesn not seem to work
    I cant seem to get the same bake as my render!
    -Zach
  • Brian Jones
    December 8, 2015 at 3:24 pm
    reflection bake is very directional – when testing I was getting black but it was on a cube on a floor with a sphere to reflect to me (the camera) and with default settings the floor is not visible in the cube (not direct line of sight) once I lifted the cube off the floor I got one face (using Optimal Mapping: Cubic) but didn’t get all faces until I checked Use Camera Vector.
