Activity › Forums › Adobe After Effects › bad renders
  • bad renders
    Posted by Linda Fox on September 19, 2006 at 6:44 pm
    I’m having glitch problems on two different G5s in my workgroup. I get big stripes across the screen in the Quicktime movies I output (SD or HD, lower field first). I have maximum RAM & AE 6.5.
    I am able to avoid problems when I output as a Tiff sequence, but I often need audio as part of the render. The renders go to Avid, and sometimes, FCP.
    We worked without problems on our old System 9 workstations, but after getting new Macs (one is on OSX 10.4.7 and one is still 10.3.9) the renders are seldom clean.
    This forum has gotten me out of a lot of jams lately. Has anyone heard of this?
    Linda Fox replied 20 years ago 2 Members · 2 Replies
  • Aharon Rabinowitz
    September 20, 2006 at 5:01 pm
    I haven’t seen this, so i can,t help with this one – however for audio, you can also just render out a WAV file or an MOV or AVI with just audio, which can be imnported into your avid system as a seperate file – it will be easy to match up becasue it will be the exact length (time) as your image sequence.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Linda Fox
    September 21, 2006 at 7:15 pm
    Thanks for your response. I’ll stop banging my head against the wall and get back to work making tiffs!
