Activity Forums Adobe Premiere Pro bad output from premiere cs4
  • bad output from premiere cs4
    Posted by Slobodan Milivojevic on October 3, 2009 at 5:34 pm
    Hi!
    I have noticed a very bad issue in Premiere/Media encoder CS4 workflow.
    Problem is that when I export HDTV 1080p, or even DV PAL WIDESCREEN PROGRESIIVE SQUARE PIXEL footage to PAL, it gives very sharp and pixelised edges of everythink……everythink looks ugly!Like its having problem with aspect ratios or maybe with aditional deinterlacing, i don’t know! Like ir is in half resolution!
    When I export from cs3, everythink is smooth and crisp!
    Vince Becquiot replied 16 years, 11 months ago 2 Members · 3 Replies
  • Vince Becquiot
    October 3, 2009 at 5:37 pm
    Is your original footage progressive?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Slobodan Milivojevic
    October 3, 2009 at 5:39 pm
    Yes man,
    this happens even with RED, HD or SD footage!
    Somethink is really bad in it!
    Try it yourself….
  • Vince Becquiot
    October 4, 2009 at 12:23 am
    I have. We work mostly in DVCPro HD, I’ve seen one red timeline so far, the export was outstanding.
    Can you give me some example of settings you’ve used?
    Vince Becquiot
    Kaptis Studios
