Activity Forums Maxon Cinema 4D Bad OBJs in Cinema 4D
  • Bad OBJs in Cinema 4D
    Posted by Jeff Klein on July 22, 2014 at 6:09 pm
    Hello. I am a novice in Cinema 4D (R13). I need to texture and render a football helmet for a client. The 3D model of the helmet was sent to me as multiple OBJs (one OBJ for each piece of the model). Each OBJ is a different random color in the attached image, just so you can see what the different pieces are. Most the helmet came in fine (the OBJs look how they are supposed to). However, a few of the pieces look funky (they have holes/errors in them). These problematic pieces include the dark green, light green, and yellow pieces in the attached image.
    I am wondering if there was an “easy” way to fix these pieces. Maybe a checkbox somewhere that says “fill in the holes” or something like that. The 3D doesn’t need to be 100 percent perfect/accurate, it just needs to be fixed enough where there won’t be these obvious errors. We could just Photoshop the stills but there will need to also be a few animations done.
    Any help would be greatly appreciated. I could post the individual bad OBJs if that would be of any help.
    Jeff Klein replied 12 years, 1 month ago 3 Members · 17 Replies
  • 17 Replies
  • Adam Trachtenberg
    July 22, 2014 at 9:20 pm
    There is a “close polygon hole” tool, but you’d have to do each hole individually. First make sure that they really are holes and not reversed or degenerate faces. I would probably start by running the align normals command.
  • Jeff Klein
    July 22, 2014 at 9:44 pm
    Hey Adam, thanks for the response. The Align Normals command didn’t work (assuming I did it right) and the “close polygon hole is not available from what I see, I’m guessing because these are imported OBJs? (again, I’m a novice in C4D). I’m going to post a C4D file which only contains for of the promlamatic OBJs. On the attached image, I’ve circled some of the problem areas which should be fairly obvious anyway. The big and most noticeable problem is the bottom one where there is a big rectangle hole missing on the left pad which is not missing on the right pad (all part of one OBJ). Anyway, if someone wants to take a look and give me any pointers. There might not be an easy fix, the problem might just be the OBJs we got from the client are bad, I just don’t see us getting anything new from them. Thanks again.
    Here is the CD4 file…
    https://dl.dropboxusercontent.com/u/12942499/_hole.zip
  • Adam Trachtenberg
    July 22, 2014 at 11:51 pm
    Hoo boy, that is some nasty geometry. Someone did a lousy job converting a NURBS model to polygons. I don’t think it has anything to do with Cinema’s obj. importer. Is there any chance you can go back to the client and ask for a cleaned up model, or barring that, get one in a common NURBS formats (like STEP or IGES)?
  • Jeff Klein
    July 23, 2014 at 12:19 am
    Thanks for the response, I’m going to see if they can send anything else but I’m not optimistic.
  • Adam Trachtenberg
    July 23, 2014 at 3:55 pm
    Good luck. If they can give your a STEP or IGES file I could try to get you a better polygon object by converting it in Rhino.
  • Jeff Klein
    July 23, 2014 at 4:03 pm
    Hey. I’m 90 percent sure these original models were created in Rhino and converted to OBJ. Any suggestions I could give the client that would result in better OBJs? Or if I could get the original Rhino file and send it to you, is there something that you could do to get me better OBJs? If it’s a lot of work we could work out compensation. Thanks again
  • Adam Trachtenberg
    July 23, 2014 at 4:47 pm
    Assuming the models are error-free in Rhino, it’s really just a matter of playing with the poly conversion settings to get a good result. Can’t really generalize too much because it’s a case-by-case thing.
    If you can get the Rhino file I’d be happy to give it a shot. It shouldn’t be that big a deal if the models are sound. Otherwise, it can be a big deal and possibly beyond my Rhino skill level.
  • Jeff Klein
    July 23, 2014 at 5:25 pm
    I’m going to speak to the client and I’ll let you know how that goes. Thanks again and talk to you soon!
  • Jeff Klein
    July 28, 2014 at 3:46 pm
    Hey Adam, I got the Rhino (.3dm) file from the client. Hopefully you can open this and do something with it. There is also an OBJ file inside this zip. Thanks, I really appreciate it!
    https://fileshare.headrushcreative.com/_zaq__qO-Vy5suR
  • Adam Trachtenberg
    July 28, 2014 at 8:18 pm
    Hey Jeff,
    Dowloading now. I’ll let you know what I find as soon as I find something. 🙂
