Activity › Forums › Adobe After Effects › Bad looking movie with alpha channel
  • Bad looking movie with alpha channel
    Posted by Art on August 4, 2005 at 2:48 pm
    Hi, I’m having problems outputting a movie with a alpha channel. I tried both animation and targa outputs which look fine outside of AE in Quicktime player but look terrible once they are imported back into AE. Any ideas?
    thanks
    Jeff Dobrow replied 21 years, 2 months ago 2 Members · 3 Replies
  • Jeff Dobrow
    August 4, 2005 at 2:54 pm
    When you bring them back in they are being interpreted correctly, yes?
  • Art
    August 4, 2005 at 3:02 pm
    Can you tell me what the correct interpretation would be for a TARGA movie? ALso, what would be the correct interpretation for a Flash movie be? I am a bit perplexed by the choices.
  • Jeff Dobrow
    August 4, 2005 at 4:30 pm
    Well, the ‘correct’ interpretation varies depending on what TYPE of alpha was exported with the image (or animation).
    AE allows for 3 options: no alpha, premuliplied alpha and straight alpha.
    On import to AE,….under the ‘interpret footage’ dialog you can select either premult or straight.
    A .tga can be either. An SWF? That is a bit more complex,….not even sure .swf supports transparency….at one time it did not,…it might now.
    Import your .tga, place it in a timline over another layer or colored bg and then try interpreting it as straight or premultiplied. If NEITHER option gives you a clean key then please post and describe what you are seeing? Perhaps the image does not even contain an alpha?…..
    More detail would help……….
