Activity Forums Adobe After Effects bad keying in AE 8
  • bad keying in AE 8
    Posted by Daniel Haworth on January 23, 2008 at 3:01 am
    Has anyone else had issues with keying greenscreen footage in AE 8 as opposed to 7? After upgrading to 8 when it came out, me and my edit staff noticed it (keylight in AE8) produced much worse edges when keying out green…here are some sample matted images to see for yourself (https://www.timanderic.com/badaekey/sample.jpg).
    So we only use 8 if we want to use the puppet tool…which is great, as are all the interface enhancement in 8…but the keying issue keeps us from totally switching over. I can’t find ANYTHING about this on any forums I’ve researched, I’m surprised we’re the only ones having this problem! All our footage is DV50, 29.97. We are pretty good at keying, and have tried tweaking all the keylight parameters, unless there is some pref or interpretation setting we’re overlooking. Anyone?
    Carey Dissmore replied 18 years, 1 month ago 6 Members · 13 Replies
  • 13 Replies
  • Darby Edelen
    January 23, 2008 at 6:29 am
    Those look like chroma jaggies. Try smoothing the chroma prior to the key or inside of Keylight (I believe they call it ‘smooth’ or perhaps ‘blur’).
    You haven’t seen anything like this ever in 7.0?
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Brendan Coots
    January 23, 2008 at 7:58 am
    Are these two clips the exact same clip with the EXACT same Keylight settings, only one is from 7 and one from CS3?
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Peter O’connell
    January 23, 2008 at 2:46 pm
    Your footage is incorrectly interpreted in AE 8. Right click the footage in the project window to open the interpret footage dialog.
    Pete O’Connell
  • Daniel Haworth
    January 23, 2008 at 10:11 pm
    yes, same footage, interpreted correctly, i think, as dv50 29.97 (see https://www.timanderic.com/badaekey/interpret.png). have tried softness and various other parameters inside keylight, it softens edges but not in a desirable way…they vibrate with motion. looks perfect in also updated to latest keylight (v1.2) in AE7 & 8(cs3), nothing seems to help.
  • Darby Edelen
    January 24, 2008 at 7:45 am
    Try turning Preserve Edges off, just a thought.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Daniel Haworth
    January 24, 2008 at 10:34 pm
    tried preserve edges on/off, 8/16 bits in projects settings, match legacy/blend colors on/off, nuthin. here’s another sample:
    https://www.timanderic.com/badaekey/sample2.jpg
    Spoke with adobe, no luck, trying keylight (foundry) now, though i suspect it’s a setting in AE.
  • Peter O’connell
    January 25, 2008 at 12:28 am
    Why don’t you download a trial of Primatte for AE to see if you can pull a primatte key that doesn’t have those jaggies (there is a dv setting in primatte). Then you will know whether it is an AE problem or a Keylight problem.
    Or you could google a technique for smoothing DV for keying by first changing the image into yuv or equivalent colourspace then blur the 2 colour channels only but not the luminance one.
    Sorry, I thought for sure it was a footage interpretation problem.
    Good Luck
    Pete O’Connell
  • Carey Dissmore
    March 23, 2008 at 7:19 pm
    I can confirm all the same problems. This is not an isolated incident. My footage is also DV50 and I’m starting to suspect a codec issue, but I haven’t nailed down exactly what is in play just yet. This is a real PITA. It’s costing me a lot of time on a very tight deadline and I can’t afford it! 70+ minutes of footage to key!
  • Jonathan Krisel
    March 25, 2008 at 5:22 pm
    To narrow it down further. I have one computer where the keying looks great in AE7 and bad in AE8. But on another computer AE7 and AE8 both look the same with bad jagged edges. I think it is a codec issue as well. Is anyone out there getting great DV50 keys in AE8? Somebody must be, right?
  • Carey Dissmore
    March 25, 2008 at 7:20 pm
    One of the infuriating things is this issue is really hard to track down, as it’s manifesting differently on different systems.
    I’ve now tested on 3 machines, one of which has 2 boot systems
    Quad G5 2.5ghz 8GB RAM
    -OS X 10.4.11, (Blackmagic Multibridge Extreme drivers)
    AE 7:
    Keys jaggy on Nucleo or multiprocessing renders, clean on standard AE renders
    -OS X 10.5.2, (Blackmagic Multibridge Extreme drivers), AE 8:
    Mac Pro Quad 2GB RAM (no video hardware)
    -OS X 10.5.2, AE 8:
    Keys jaggy on Nucleo or multiprocessing renders, jaggy on standard AE renders
    Macbook Pro Core 2 Duo 2GB RAM (no video hardware)
    -OS X 10.5.2, AE 8:
    Keys jaggy on Nucleo renders, jaggy on standard AE renders.
    So the only way I can get a clean key rendered right now is to use the first machine, with Nucleo or multiprocessing disabled.
    What a PITA! (slowing me down—lost about 4-5 hours to troubleshooting this!
