Activity › Forums › Adobe Premiere Pro › Bad Firewire port – need cheap camera with RCA inputs
  • Bad Firewire port – need cheap camera with RCA inputs
    Posted by Rob Webster on September 23, 2006 at 3:55 pm
    My firewire port on my Sony PD-150 has gone out, and Premiere Pro 2.0 has a rare compatibility issue with the Panasonic DVX100, it seems. I’ve never really liked using my cameras as my playback decks, anyway, so I want to get a cheap camera just for capture and playback. I’d also like one with RCA inputs, as my work often entails re-editing from DVDs and I need to be able to pass-thru directly through a camera. Any suggestions?
    Rob Webster replied 20 years ago 4 Members · 5 Replies
  • Vince Becquiot
    September 23, 2006 at 4:09 pm
    How about a Canopus ADVC box. That’s under $200.00.
    Vince
  • Tim Kolb
    September 23, 2006 at 4:33 pm
    My thought exactly, though you still might want a cheap DV camera for direct FW transfer…I’m not sure how plentiful they are at the bottom end with analog inputs.
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Phocas Kroon
    September 23, 2006 at 7:33 pm
    Check Canon MV 700i with analog pass through.
    Price in The Netherland EUR 470,-
    Good luck
    Phocas Kroon
  • Rob Webster
    September 23, 2006 at 8:10 pm
    Is that the same as the ZR700 in the states? It seems to be, as best I can tell. Excellent suggestion. Thanks!
  • Rob Webster
    September 23, 2006 at 8:14 pm
    I hadn’t thought about that – that’s a very good option. Though I kind of like the idea of having a little camera instead of my $3600 camera. That way if I need to strap it to a helmet or wrap it in plastic for a rafting trip, I’m not risking as much. Realistically, though, after years of doing this, I haven’t had many opportunities for shots like that. But maybe I’d seek more out, too. 🙂 Next thing you know, I’ll be strapping cameras to my toy remote controlled helicopter. Thanks for the suggestion!
