Activity › Forums › Apple Final Cut Pro Legacy › Bad compression on fast-motion video
Posted by Paul Ravillino on April 11, 2009 at 3:28 amHello,
I have some footage in my timeline that is sped up to about 350%. It looks crystal clear while still in FCP. I’m exporting the project to Quicktime using the H.264 codec with the highest quality possible.
Once a Quicktime file, the sped up parts don’t look clear anymore, they almost seem to have horizontal lines race across the screen where the action is.
I can provide a link to an online sample if that will better illustrate the problem….
Does anyone know how to deal with this? I need to export this video for TV broadcast, and these lines are just embarrassing.
Paul
Paul Ravillino replied 17 years, 5 months ago 6 Members · 12 Replies -
Rafael Amador
April 11, 2009 at 3:38 am -
Andrew Kimery
April 11, 2009 at 8:37 amAre you working w/interlaced footage, is your Canvas window set to 100%, and are you viewing this on a broadcast monitor?
-A
3.2GHz 8-core, FCP 6.0.4, 10.5.5
Blackmagic Multibridge Eclipse (6.8.1) -
Tom Wolsky
April 11, 2009 at 9:23 amSo where’s the sample?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Paul Ravillino
April 11, 2009 at 3:59 pmI’m using the H.264 in the Quicktime export option. Is that what you mean by setting?
Paul Ravillino
April 11, 2009 at 4:01 pmI think the footage is interlaced? I’m not sure. I imported it from mini DV tape, into a regular NTSC timeline. How can I find out if it’s interlaced?
Paul Ravillino
April 11, 2009 at 4:02 pmYou can see a sample here https://popboom.net/viewer.php?vid=660
The video in question is right at the beginning.
Michael Sacci
April 11, 2009 at 5:00 pmOnce again, details need to be given.
How was this shot? This looks like pull down that you find on a DVX/HVX shot at 24p onto tape. If so this is a import, not an export problem.
I would be surprised if this is on the sequence footage in FCP but you are not using an external monitor and your canvas is NOT set to 100%, which would cause this problem to be hidden from you.
It may also be introduced when you are adding the speed changes to the clip, was again you need to be viewing your FCP timeline on an external monitor, only way to catch these things.
That being said, exporting a ref movie (or self contained movie) from FCP and then taking that into Compressor, gives you more control and in the end better quality.
You should also take the time to learn general terms of our industry, no crime in not knowing what “interlaced” means but our first response should be to look it up and not ask what it is.
Andrew Kimery
April 11, 2009 at 7:50 pmIf it’s going for b’cast you have to judge the image on a monitor that will properly display interlaced video (such as a broadcast CRT monitor). You can’t properly judge the image by viewing it on your computer monitor.
Does the network/channel you are delivering to really specify h.264 as the codec it wants?
-A
Paul Ravillino
April 11, 2009 at 9:08 pmOkay, it looks good on a TV monitor… I didn’t realize that a computer monitor would be that different.
They didn’t specify that I compress it using H.264. They didn’t specify anything. I assumed H.264 would work well. Is there a better way to do it for TV?
Ben Avechuco
April 11, 2009 at 9:29 pmYou might try deinterlacing the footage first…
Effects>Video Filters>Video>De-interlaceAlso, make sure you have Frame Blending checked in the Time Remap section of the motion tab for your footage.
