Activity Forums Adobe After Effects Expressions Bad argument:couldn’t find layer…
  • Bad argument:couldn’t find layer…
    Posted by Peter Vyrostko on December 11, 2009 at 1:46 pm
    somehow I got this error message on every expression from a nested composition.
    I have a parent(master)composition with an adjustment layer containing expression controlers over the effects in the nested compositions. All the controlers refers to a compositions with a different names, no duplicated compositions To some point it worked perfectly.
    Suddenly I got the error message for all the expressions used in master composition….Bad argument:couldn’t find layer…
    I get this message even if I directly use expression whip to link it directly to the effect slider.
    I recently updated to CS4 from CS2, and I don’t know if this is some feature I accidentally had turned off.
    any suggestions ?
    thanks
    comp("Master").layer("Efekty").effect("Glow Opacity")("Slider")
    Peter Vyrostko replied 16 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 11, 2009 at 4:17 pm
    Can you cause this to happen every time, or does it seem to be random?
    Dan
  • Peter Vyrostko
    December 12, 2009 at 11:28 am
    I actually have solved this.
    Using capital letters confuses CS4.
    After renaming all the compositions it worked.
    I recently upgraded from CS2 to CS4, and I never experienced this.
    I kind of expect to experience various problems, since I always use capital letter in names of compositions and layers…
    Any fix to this ?
    I am using win7
    Peter
