Activity Forums Adobe After Effects Expressions Bad argument: index out of range
  • Bad argument: index out of range
    Posted by Jeremy Steel on October 8, 2009 at 1:23 am
    I’m trying to link the flare center of a flare effect (on null layer) to the position of null layer–Track moon–with tracking info (x, y). I feel like I’ve done everything right according to the tutorial I’ve seen (admittedly I’ve made a few adjustments to personalize it according to my project’s needs). I used the pickwick to link to the “Track moon” null layer’s position. Any ideas where I might be going wrong?
    Jeremy
    effect("Lens Flare")(thisComp.layer("Track moon").transform.position)
    Jeremy Steel replied 16 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 8, 2009 at 7:14 am
    I’m not sure how you ended up with that, but you should only need this part:
    thisComp.layer(“Track moon”).transform.position
    Dan
  • Jeremy Steel
    October 9, 2009 at 4:36 am
    Well I don’t need to tell you but … YES, that did the trick. Thank you Dan!
    -Jeremy
