Activity › Forums › Adobe After Effects › Backround/Wave Generation
  • Backround/Wave Generation
    Posted by 3d3 Visualisation and 3d animation on July 13, 2005 at 1:40 pm
    Can anyone help? I need to create a disco/psychedelic style moving backdrop to run as a continuous loop. The idea is that children singing will be dropped in over the top of it and it should suggest that they are in a pop world/universe. Is the best way of doing this to use a wave generator in AE. Are there any good plug ins that offer lots of options for creating morphing backgrounds?
    3D3 // architectural visualisation and 3d animation
    Jim Dodson replied 21 years, 2 months ago 3 Members · 2 Replies
  • Aharon Rabinowitz
    July 15, 2005 at 4:31 am
    Try the effect called Fractal Noise (under the noise and grain section of effects), which can be used to make looping fractal Backgrounds – they are Black and white however. One of my favorite effects becasue its so versatile.
    To colorize them, use the effect called Colorama – which I believe is under the effect section called Image control.
    It takes the black and whites and based on luminance assigns a color. At least I think that’s how it works. I haven;t looked at it in a long time.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Jim Dodson
    July 17, 2005 at 2:58 am
    Or use Render–> FRACTAL (not fractal noise)
    choose set choice: Julia
    add 2 keyframes to magnification: 1st one -13 (that’s negative 13) and the 2nd one 100
    and watch a magnificently colorful acid trip present itself…
