Activity Forums Apple Final Cut Pro Legacy Backing up multiple hard drives
  • Backing up multiple hard drives
    Posted by Miodrag Ristic on July 2, 2008 at 12:23 pm
    I want to back up my two hard rives (300 GB and 500 GB) to a 1TB hard drive.
    Do I have to partition 1 TB drive into two partitions or
    I can just back them up it as is?
    It was a long day (after a storm I realised that one of my external back up hard rives is playing up,
    and that my system drive wasn’t backed up as bootable at all, SuperDuper used) and I’d appreciate your help.
    Mick
    Jerry Hofmann replied 18 years, 2 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    July 2, 2008 at 12:47 pm
    Then one of the two drives is a boot disk? I’d partition the TB drive…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Miodrag Ristic
    July 2, 2008 at 2:03 pm
    Thanks Jerry,
    Yes, one is a boot disc (Macintosh HD).
    That means, partition for bootable to be Journalled,
    and other partition to be Journalling Off. Correct?
    I used Super Duper to make a bootable copy, and that might have caused problems.
    It was never bootable, and every time after the back up. my G5 would freeze.
    After forced quit (switch button) Mac (Finder) would struggle to open any
    window let alone an application.
    Apparently, Mac would just be hanging – not being able to establish from which drive to run.
    Mac technician suggested a faulty drive? Data is there, but it’s not bootable.
    Would Carbon Copy cloner be better or should I use WD Anywhere Backup (supplied with my Western Digital), or maybe something like retrospect?
    Mick
  • Jerry Hofmann
    July 4, 2008 at 2:12 pm
    I’ve always had pretty good luck with SuperDuper actually… don’t know much about the others.
    Don’t think it matters about turning Journalling on or off for the second partition, but should be on for a bootable disk.
    Does sound like the drive is going south though if it’s super slow.
    Jerry
