Activity › Forums › Adobe Illustrator › backgrounds on objecs in Illustrator
  • backgrounds on objecs in Illustrator
    Posted by William Thompson on December 23, 2013 at 9:06 pm
    Hello Forum.
    How do you make the background of an object transparent in Adobe Illustrator?
    I have been having issues with using the Magic Wand tool in Adobe Illustrator as well as the lasso tool.
    Basically, I am trying to put a small graphic into a new Illustrator file.
    The first thing I tried to do is to use the magic wand tool. But I found out that this did not work on a jpeg image since it did not have any individual objects to select.
    So I tried something new. I opened the file in Adobe Photoshop and used the lasso tool to select an area. Then I coped this area. Then I tried to paste it into Adobe Illustrator. But the background was not transparent for the pasted image.
    How do I make the background transparent.
    I made this small video to show what I am talking about:
    https://youtu.be/KQrovAq59zk
    I noticed that the background is a layer in the image I made in photoshop. I tried turning it off or making it invisible, but that did not help.
    https://i67.photobucket.com/albums/h292/Athono/hidebackground_zps0338ed4b.png
    https://i67.photobucket.com/albums/h292/Athono/backgroundinphotoshop_zps04ea33fd.png
    Vincent Rosati replied 12 years, 8 months ago 2 Members · 1 Reply
  • Vincent Rosati
    January 6, 2014 at 1:53 am
    To get a vector out of Photoshop
    Make your selection, as you did.
    Than Window / Path / Make work path.
    There is a Work Path button at the bottom the the Path palette, or in the Path drop-down menu.
    Now you can File / Export paths to Illustrator.
    This will create a file with the path objects in the PS file.
    Now back in AI, you can add a color as a fill. Or if you need the raster texture you can paste it in (or better, File / Place an external resource TIF or PSD), than use the path as a clipping mask on the raster.
    Let us know.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
