Activity › Forums › Maxon Cinema 4D › Background won’t render in Quicktime
  • Background won’t render in Quicktime
    Posted by Jim Scott on December 8, 2014 at 2:57 am
    I have a Background Object with a jpeg applied as a texture. The background shows properly when rendered in the View window as well as the Picture Viewer. However, when rendering out a Quicktime Movie file (rendering single frames for testing, if that makes a difference) the background renders only black. If rendered as a pict file it renders the image properly. I must be missing some setting but can’t find it. Any help would be greatly appreciated. I’m using R13 Studio on a Mac.
    Jim Scott replied 11 years, 9 months ago 2 Members · 3 Replies
  • Jim Scott
    December 8, 2014 at 5:26 am
    Apparently the Alpha Channel messes up the Quicktime file so unchecking it in the render settings solves the problem.
  • Brian Jones
    December 8, 2014 at 3:38 pm
    To save an Alpha channel in Quicktime you’d probably want to be using Animation codec with colors set to Millions+
  • Jim Scott
    December 8, 2014 at 4:40 pm
    Thanks Brian. I appreciate the insight.
    In this case I wasn’t trying to save an Alpha Channel, but apparently it was interfering with the Background rendering properly.
