Activity Forums Apple Final Cut Pro Background Removal of a handheld shot?
  • Background Removal of a handheld shot?
    Posted by Geoff Gross on September 1, 2024 at 9:46 pm
    Hi all –
    Is anyone aware of any tools to remove backgrounds from a handheld shot? I’ve tried a few: veed, descript, and adobe, and all are removing too much in my case, but don’t have any parameter adjustments to play with to fine tune the removal.
    Geoff
    Geoff Gross replied 1 year, 4 months ago 3 Members · 5 Replies
    September 2, 2024 at 1:04 am
    Hey Geoff,
    Have you tried CoreMelt SliceX (it uses Mocha for tracking).
    https://coremelt.com/products/slicex-powered-by-mocha
    You might want to have a look at the whole bundle, if there is more that you can use:
    https://coremelt.com/products/detonators-bundle-fcpx-tracking-vfx-paint-stabilisation-and-more
  • Geoff Gross
    September 2, 2024 at 6:01 am
    Thanks Mads! That sort of did the trick. It’s not perfect, but it’s better than anything else I tried. Since I’m messing up and distorting these clips, with a little more masking, I think it might be good enough for my purposes.
    Appreciate the coremelt tip – (anvil seems like the right tool tho, not slice.)
    September 2, 2024 at 9:05 am
    Hey Geoff,
    Great that you found Anvil – had not thought of that.
    Admittedly I am not using FCPX much these days, and less so Coremelt.
    But Mocha is always a trusted friend, and Coremelt saw that too.
  • Jonathan Howells
    September 4, 2024 at 11:50 am
    Hi Geoff,
    Sounds like you’ve got your results, but another great tool is from Motionvfx, called mRotoAI
    Check it out for next time
    I use it in Motion5, and it works REALLY well
    https://www.motionvfx.com/store,mrotoai,p3922.html
  • Geoff Gross
    May 7, 2025 at 3:10 am
    Thanks Jonathan – I’m not too good in motion, but perhaps this will be the impetus to learn it next time, haha.
    I’ll check out mRoto!
    Geoff
