Activity Forums Adobe Premiere Pro Background Noise
  • Background Noise
    Posted by Mr_steven on July 29, 2006 at 6:13 pm
    I’m working with some footage that was recorded with the levels too low down. I’ve turned up the volume but I now get an awfull background hiss.
    What is the best way to remove this background noise ?
    Cheers,
    Steven.
    Rex Summerfield replied 20 years, 1 month ago 4 Members · 6 Replies
  • Steven L. gotz
    July 29, 2006 at 6:45 pm
    Adobe Audition. You sample the noise and it deletes it from the entire file.
    Steven
    https://www.stevengotz.com
  • Aanarav Sareen
    July 29, 2006 at 8:44 pm
    Adobe Audition is the ideal tool. However, if your background audio only consists of hiss, check out the DeHummer effect.
  • Mr_steven
    July 29, 2006 at 10:17 pm
    Thanks guys, I’ve just downloaded the trial version of Adobe Audition, it’s tricky to use. I can select the audio for the video and the effect but I can’t see the video at the same time, nor can I add volume, unless I turn up the levels, which I guess is ok.
    Cheers,
    Steven.
  • Mr_steven
    July 29, 2006 at 10:21 pm
    Anarav,
    I can’t find de hummer, only de noiser, which does help, but between the lines of dialogue you get this kind of wind going through a tunnel sound effect that comes and goes.
  • Aanarav Sareen
    August 1, 2006 at 2:45 am
    What version of Premiere Pro are you using? Please see this link:
    https://www.aanaravs.com/misc_images/DeHummer.jpg
  • Rex Summerfield
    August 1, 2006 at 3:58 am
    You can also get rid of most of the mic hiss by applying the treble effect. Its simple quick and not too noticable if its basic audio underneath like talking. The de-hummer removes most camera hum but the Bass effect will remove quite a bit as well.
    R Summerfield
    Shiloh Outdoor Productions
